Default Early TH-400 to 258
Old 04-04-2011, 03:09 PM   #1
gr8cj8 is offline
gr8cj8
Vehicle(s): 1982 Scrambler, 258-6 dual port Offenhauser intake with 390 cfm holley 4 bbl. carb. dual header clifford exhaust. early AMC housed th-400 with adaptor ring. Dana 20 transfercase and stock differentials.
gr8cj8's Avatar
Rep Power: 0 gr8cj8 is on a distinguished road
I have an early Turbo 400 with the adaptor ring and dana 20 Im having troubles making work in my Scrambler.
The problem is when I get to installing the flexplate, the flexplate lines up perfectly with the starter but when I bolt it up to the torque convertor it pulls it out of the Tranny a 1/2 an inch to far so it wont engage.
My engine is the 258 and hopefully someone out there has done the same and may have some input.
Default Re: Early TH-400 to 258
Old 04-04-2011, 08:03 PM   #2
fzsk4p is offline
fzsk4p
Vehicle(s): Ground up YJ. Looking to get a CJ
Rep Power: 8 fzsk4p is on a distinguished road
The flexplate bolts to the crank at the small diameter. At the outer edge it bolts to the converter. So there is no way that it can be pulled back by the converter because it is bolted to the crank. I can see the converter moving out a 1/2 inch but not the FP.
Old 04-06-2011, 02:18 AM   #3
gr8cj8 is offline
gr8cj8
gr8cj8's Avatar
Wow, thank you teacher! I came here for some help not corrections.
Its obvious I made a mistake, yes the torque convertor pulls out so if youve come to this board to give people a hard time and no answers and I really appreciate that.
Old 04-06-2011, 08:50 AM   #4
Images: 219
Lighten up Frances (A favorite movie quote ) Knock off the sarcasm - it's not needed, I thought the post fzsk4p gave was spot on. I was confused as well by your post. It wasn't obvious to me you made a mistake as there could have been other problems. If you ask for info, try and give accurate
information. This post is just to help us help you.
Your post is still vague, I think what you are saying that 'it' (the torque converter) will not engage the pump on the trans. Right?
I have never used and adapter ring but I would assume that a standard torque converter would only work if you had some sort of spacer that was the same thickness as the spacer or a special converter with a long snout or welded on spacers to account for the new ring.
Who makes the ring and how thick is it?
Old 04-06-2011, 10:57 AM   #5
fzsk4p is offline
fzsk4p
Thanks CJ.
Old 04-06-2011, 01:19 PM   #6
derf is offline
derf
Vehicle(s): 1984 CJ7 - 5.3/4L60E/Atlas4spd/D44/9" - In Progress 1984 GW - 360/TF727/NP229/D44/M23 - NP242 swap in progress 1986 J10 - 360/TF727/NP208/D44/D60 - 700R4 upgrade in the works
derf's Avatar
Rep Power: 8 derf is on a distinguished road
In the early 70's, the FSJs had a spacer adapter to go between the AMC bolt pattern block and the "universal" pattern bellhousing. I'm not sure but I believe that they used a flex plate that also came with a spacer. If you don't have the spacer for the flex plate, the torque converter would pull out like you are seeing.
It could also be that in those early days they used a specific flywheel to go with the adapter ring. That would build in the spacing you need to run with the adapter ring. When they switched to an AMC pattern transmission case they would have changed the flex plate. Obviously they wouldn't be interchangable.
If there isn't someone here who knows, you chould check over at the full size Jeep boards: International Full Size Jeep Association to see if some of them know exactly what you need.
The Following User Says Thank You to derf For This Useful Post:
gr8cj8 (04-08-2011)
Old 04-06-2011, 03:53 PM   #7
fzsk4p is offline
fzsk4p
At first what CJ was saying is what I thought the question was. A spacer of some sort needed for the converter bolts.
What threw me is the OP`s reference to the starter and "something" getting pulled out by a half inch. To me it sounded like the FP getting pulled back and not engaging the starter.
Derf makes a good post on the FSJ`s and the universal adapter plate/concoctions needed to bolt everything up.
Hopefully the OP will come back and explain his issue again.
Old 04-07-2011, 09:21 PM   #8
gr8cj8 is offline
gr8cj8
gr8cj8's Avatar
Thanks, I think Im going to resolve my problem eventualy and may start a new thread based on it.
Right now Im about to go to a Transmission shop here in anchorage to check out a 1973 flexplate and see if its different than the one I have now.
There were 3 TH-400 Transmissions made.
1. Your typical GM TH-400
2. The AMC housed TH-400
3. The early Universal housed TH-400 that could be purchased by other auto makers like Jaguar and AMC that would provide thier own adaptor ring for thier applications.
Derf you are correct
Old 04-08-2011, 11:23 PM   #9
gr8cj8 is offline
gr8cj8
gr8cj8's Avatar
Oh CJ the gentleman that responded to my post has no idea what hes talking about in my mind when it comes to CJ's because he doesnt even own one. He was just responding to respond.
I shouldnt even have have become sensitive and left it alone but let my pride get in the way.
Then I realized you were the first member and an admin. You of all people should know better than participate in such a thing.
I recieved 1 respectable comment and I appologized for my inappropriate behavior and forgive you for yours.
Old 04-09-2011, 12:49 AM   #10
fzsk4p is offline
fzsk4p
What a kind thoughtful person.
Guess a YJ doesn't count cause it is a totally different breed, right ? I mean they are put together completely different then a CJ. And a CJ engine/trans is completely different then any other.
Wonder how I managed to mount up an NV4500 to a stroker 4.0 ? Dumb luck `eh ?
30 years in performance builds. Hell maybe I should go to Vegas with that luck.
258 , early , th-400
Anyone into an early CJ? thiswontbetooexpensive Great Deals! 0 03-28-2013 02:17 PM
Early cj, 5.38's not low enough gliryan Drivetrain 30 07-25-2012 09:54 PM
Early Cj-5 Petescj Great Deals! 1 10-02-2011 01:56 PM
Early Cj-5 tub Petescj Misc CJ Discussion 2 04-11-2009 07:17 PM
Early Cj5 guys LOOK Petescj Misc CJ Discussion 0 04-08-2009 06:04 PM
