Dana 44 rear disc brakesThis is a discussion on Dana 44 rear disc brakes within the Drivetrain forums, part of the CJ Forums category; Who makes the best Dana 44 rear disc brake kit?...
06-18-2010, 07:26 PM
Vehicle(s): 86 CJ7 258, T18, Scout 300,twinstick ,Dana 30 LS Dana 44 locker 3:73's,4"lift ,1" body.York OBA,
Warn 8274,Fullcage.
Re: Dana 44 rear disc brakes
06-18-2010, 07:50 PM
72 CJ5 Owner
SS Brakes supplies a nice kit - expensive but it has everything to convert. Your CJ should have had an AMC 20, what year and make of D44 do you have?
SSBC :: SSBC Performance Brake Systems
06-18-2010, 09:19 PM
Warn 8274,Fullcage.
I've got one of the last CJ7's a true 86 with the factory Dana 44.
06-18-2010, 11:52 PM
Vehicle(s): 1975 CJ-6 with 304/T-15/Dana 20/30 and 44 with 3.73, 1986 CJ-7 Laredo with 4.6 stroker/T-5/Dana 300 and 30 and 44 with 3.31, 1983 CJ-8 with 258/ T-5/Dana 300 and 30 and 20 with 2.72, 1986 Trail Jeep in the works with TDK frame/4.0/AX-15/Dana 300 and 44s front and rear/full P.S. armor.
I have a couple of those late 86 44s and several Model 20s, whats funny is that they use the same brake parts as the 20. Even the backing plae is the same except for the hole is larger to pass over the bearing and the 4 bolt holes are larger. I would really think (based on my comparison) that a model 20 kit could be used on a late CJ 44 with a little mod work. The main show stopper would be the bracket that bolts to the tube flange would need to be larger to fit the thinker tube and larger bolt patter.
Here's alink that I found for one of the few companies that has one just for the late 86 CJ 44...
CJ-7 '86-'87 Dana 44
Ed 1975 CJ-6 1986 CJ-7 Laredo 1982 CJ-8
1983 CJ-7 Trail Jeep in the works 1983 CJ-8
06-19-2010, 04:27 AM
72 CJ5 Owner
Most kits for the read D44 use Lincoln calipers. The TSM site is great and you will get everything you need.
I wasn't in the mood to buy pieces when I converted my CJ so I went with SS.
Both company's will get you stopping, TSM is cheaper.
