Default Dana 20 Problem
Old 03-18-2011, 06:31 PM   #1
Harlen Shaw is offline
Harlen Shaw
Vehicle(s): '84 CJ7 fiberglass tub, AMC 360, T18, D20, D30 front, AMC 20 rear 2000 Doge Ram 1500 Ducati Streetfighter Kawasaki 650
Rep Power: 0 Harlen Shaw is on a distinguished road
I have a dana 20 that only shifts 4h 2h and 2l (no 4l). I'm not sure exactly how they work and was wondering if any of you might know whats wrong before I take it out and start taking it apart to try and figure it out. Its not stock and was put on the Jeep before I bought it. Other than not shifting into 4low it seems to work great.
Default Re: Dana 20 Problem
Old 03-18-2011, 06:53 PM   #2
Saddle Tramp is offline
Saddle Tramp
Rep Power: 9 Saddle Tramp is on a distinguished road
If the 20 is not original to your jeep then it could be the FSJ version which pushes to the side and then forward; the CJ version is straight front to back. See Pictures.
Old 03-18-2011, 08:19 PM   #3
Resident 'Old' Jeep Shaman
Images: 141
the Dana 20 is closely related to the D18
and it has a simular shifting pin setup, If you have a twin stick that will not go into 4 low a good place to start is in the shifter pin area.
what I mean is there are 2 pin things (shifting rails)that the shift forks are connected to, if they are blocked from moving properly they will inhibit the shifting process.
Now if this is not the case I strongly suggest pulling the tranny and case at the same time and opening the case up, it seems that you can drop parts if not careful when handling them separate. Or maybe I am just a fumble thumb.
Anyway once out and connect to the tranny, operating the case is easy and if the case needs internal help you have everything together to see how it fits back together.
Old 03-18-2011, 08:26 PM   #4
Harlen Shaw
Its definitely not the FSJ version only move straight forward and back. I looked underneath its not possible for the side movement.
Old 03-18-2011, 08:31 PM   #5
Harlen Shaw
Its a single shifter that is connected to two input shafts. I'm not sure which one affects which part of the T-case. From what I can tell nothing is blocking it. Gonna play with it a little more hope fully its something simple.
Thanks for the advice on dropping the transmission at the same time, guess that'll be a good time to replace the cracked bell housing.
Old 03-18-2011, 08:42 PM   #6
Images: 141
ok there may be a interlock between the pins sticking
and I am not sure if it is true with the D20, but a D18 shares fluid with the tranny
Old 03-18-2011, 08:56 PM   #7
there is not a 2L unless it is twin sticked.
I would want to check the front output shaft shifting fork set screw. I would definatly say it has something to do with the front output shaft gear not moving weather from linkage or the fork being loose on the shaft. If the shaft is moving there has to be something loose or missing inside.
Old 03-18-2011, 09:03 PM   #8
Images: 141
that is right
check the shfter mechanism for sure
Old 03-18-2011, 09:33 PM   #9
Harlen Shaw
This it what it looks like in 4H all the way forward. When I shift it one position back to 2H the shaft on the left moves back one position and the one on the right stays where it is. When I put it in N the shaft on the left stays put and the shaft on the right move back again. When I put it all that back into 2H which I believe should be 4H the shaft on the left stays put and the shaft on the right goes back another position.
Hope it makes sense how I described it. A little chart below kinda describes the position on each shaft in each setting. 1 is the most inward position and 3 is the most outward position. I'm pretty sure that just the left shaft should have one more position but I'm not sure exactly which way it should be for 4L
Left Right
4H 2 3
2H 1 3
N 1 2
2H 1 1
Old 03-18-2011, 09:43 PM   #10
the point is that the shafts move when the shifter is moved, is this right ?? If this is the case the front output shaft shifter fork is not moving the sliding gear into the 4 low position. the 4 H position is a completely different set of gears.
please fill out your profile .
dana , problem
dana 44 problem rr41mag Drivetrain 4 04-23-2013 06:13 AM
Dana 30 axle with Dana 44 brakes Seeverest Misc CJ Discussion 5 02-17-2012 06:41 PM
DANA 44, Dana 30 and transfer case ID HELP!!!!!! Texxas Drivetrain 1 06-05-2011 10:40 PM
'86 Dana 300 Transfer Case Shifting Problem MDJEEPER Drivetrain 10 03-15-2010 06:50 AM
Dana 300 T-case Problem coltat4wp Drivetrain 17 03-12-2010 12:01 PM
