Default Clutch play HELP
Old 07-28-2013, 07:32 PM   #1
jeremy5780 is offline
jeremy5780
Vehicle(s): 1985 cj7
Rep Power: 5 jeremy5780 is on a distinguished road
I have a 1985 cj7 straight 6 4.2L Bought a few months ago and slowly doing a little work. The clutch seems to work fine shifts smooth. but I noticed there was a lot of play in the pedal. It would go down 2-3 inches before getting hard then I noticed the clutch only engages in about the last 2-3 inches of the pedal before it hit's the floor or bottoms out. So I decided to get underneath and check it out, and this is what I found. I attached a video. If you could take a look and let me know what you think. I went through all the receipts the PO gave me and it looks like he put in a new center force clutch set, clutch disc, linkage kit and throwout bearing in 2004. Thanks
https://www.youtube.com/watch?v=iTkPHHXnq2I
Default Re: Clutch play HELP
Old 07-28-2013, 07:49 PM   #2
Texian is offline
Texian
Vehicle(s): 1978 CJ7 V8 AMC20 D30 T150 Dana 20,4" lift,33" BFG KM2's,Detroit Lockers front & rear,4.10 gears,1 piece axle,Warn 9.5 XP Winch,Hi-Lift X-treme on the hood,Warn Rock Crawler Frt. & RR Bumpers,Warn Rock Crawler Tire Carrier,Supertop
Texian's Avatar
Rep Power: 5 Texian is on a distinguished road
Everything looks normal,you just need to adjust the free play as measured at the pedal.
Loosen the jam nuts and take out free play until you have about 1" at the pedal.Retighten the jam nuts .
Old 07-28-2013, 08:04 PM   #3
jeremy5780
Ok I wasn't sure there was suppose to be that much play in the metal piece that sits in the boot where the plastic ball sits.
Old 07-28-2013, 08:13 PM   #4
Texian is offline
Texian
Texian's Avatar
You are fine except for the free play.
clutch , play
New to forum and just got a CJ5 to play with WSS Introductions 12 03-07-2013 12:47 PM
shaft play drivert51 Drivetrain 14 02-26-2012 08:46 PM
Let's play a game!!! CJ007 Misc CJ Discussion 10 10-20-2011 06:27 PM
Pitman arm play RTRCJ7 Suspension and Steering 4 07-30-2010 06:16 PM
Play in the WHEEL! Rusty Shank Suspension and Steering 7 05-09-2010 08:22 AM
