Exclamation CJ-7 Rebuild
Old 07-10-2011, 01:49 PM   #1
BTC is offline
BTC
Vehicle(s): 1979 Jeep CJ7,1984 Jeep CJ7
Rep Power: 0 BTC is on a distinguished road
I have a 1979 CJ-7, 5.0 V8, Auto tranny with QT basically stock. I'm in the process of rebuilding it from the ground up and in the process I have come across many donor parts from a 89 YJ with a 4.2 258 I6 and AX-15 5-speed.
I have 2 options that I'm toying with, 1) Placing the CJ on the Yj frame and using the YJ motor and tranny and 2) Using the YJ AX-15 with my CJ.
Would it be difficult to place the CJ body and cowl on the YJ frame?
Would it be easy to mount the 258 on the CJ equipped with V8 mounts and what is involved?
Is the AX-15 compatable with the CJ QT or do I need to swap axles too?
Thanks ahead of time.
Default Re: CJ-7 Rebuild
Old 08-03-2011, 02:15 PM   #2
Jimbos76cj is offline
Jimbos76cj
Vehicle(s): 83 CJ-7.. 4" YJ springs front rear, J-10 44 front/AMC 20 rear,6 cy auto dana 300 35' bfg Done and gone!! Ask me about my head light upgrade harness!!!
Rep Power: 8 Jimbos76cj is on a distinguished road
Im not sure how far you got in this post since its old but I thing the CJ tub on the YJ frame would be easier then swaping the YJ power train into the CJ
swapping the YJ power train would require the moving of the axles and the springs are different sizes.
If you did do any of this and you have a set of v-8 motor mounts from the CJ available id be interested in buying them.
cj-7 , rebuild
79 V8 CJ7 rebuild wondernad CJ Build Forum 17 11-25-2012 05:52 PM
Rebuild CJ or buy JKU sponge Misc CJ Discussion 42 06-09-2012 10:59 PM
Where to get rebuild kit? 4.2 coldair Drivetrain 15 04-10-2012 06:20 PM
New rebuild now will not run mikeralph Drivetrain 7 03-09-2012 09:59 PM
Rebuild kit for T-15. CJ Drivetrain 12 02-04-2009 05:16 PM
