Default Re: Choke Question?
Old 06-14-2010, 12:22 PM   #11
Vehicle(s): 1977 cj-5 4.2 2bbl carter "upgrade".TFI ignition with MSB6 offroad module,CS144 140 amp RPS alternator with remote regulator T-150,d-20,Amc20. D-30, skyjacker 2.5 lift?nitro shocks,31" BFG A/T off road. 1981 J-10 4.2 with 4.0 head and 3 angle valves, headers, T177, NP208, AMC20 wide track with factory one piece axles. D44 front.
Images: 39
Rep Power: 3 IOPort51 is on a distinguished road
I am hesitant to say this but is it possible the mixture screws are leaned out to the point that it needs choke to run?? I'm looking for other opinions on this.
Old 06-14-2010, 08:00 PM   #12
priceg is offline
priceg
Vehicle(s): 1982 CJ 7 4.2liter T176,D300,D30,AMC20
priceg's Avatar
Rep Power: 1 priceg is on a distinguished road
On a bbd the metering screws should be between 1.5 to 2 turns out. Their is a possibility that the metering rod well is stopped up and choking it is forcing engine vacuum to pull the fuel past the rods to the main jets. Kind of like a stopped up pilot jet. Its tough to speculate.
Old 06-15-2010, 10:41 AM   #13
phinleft is offline
phinleft
Vehicle(s): 76 CJ5, 4.2 L, inline 6, everything stock
phinleft's Avatar
Rep Power: 0 phinleft is on a distinguished road
Should I screw the mix screw in all the way, and back it out two full turns? At this point, I am willing to try anything. Taking the jeep to a mechanic is my last option, because I am trying to keep a tight monthly budget. I will do it if I can't come up with anything else.
Old 06-15-2010, 10:58 AM   #14
priceg is offline
priceg
priceg's Avatar
Go ahead and remove them and spray some carb cleaner in the ports, then reinstall them. Screw themin untill they stop, do not force them in or you will bend the tips. Then back them out 2 turns. At least you will know that setting is correct.
Old 06-15-2010, 01:15 PM   #15
phinleft is offline
phinleft
phinleft's Avatar
When you refer to "them". I want to make sure you are talking about the air/fuel mix screw and the ide screw, correct? Want to make sure we are on the same page.
Old 06-15-2010, 01:22 PM   #16
priceg is offline
priceg
priceg's Avatar
correct.Carters actual name for them is Idle Adjusting Needles
Old 06-15-2010, 01:51 PM   #17
phinleft is offline
phinleft
phinleft's Avatar
You all are very helpful! Thanks!
Old 06-16-2010, 02:27 PM   #18
phinleft is offline
phinleft
phinleft's Avatar
Tried flushing everything out with carb cleaner. No good - Choke won't open up fully. Here are pics. Is anything connected wrong?
http://i959.photobucket.com/albums/a...00616-1052.jpg
http://i959.photobucket.com/albums/a...00616-1038.jpg
Old 06-16-2010, 04:15 PM   #19
priceg is offline
priceg
priceg's Avatar
You have a YF. Unplug the line next to the fuel line. that is a bowl vent and needs to be open to atmosphere.
Old 06-16-2010, 05:02 PM   #20
phinleft is offline
phinleft
phinleft's Avatar
Why would the PO have plugged it?
carb, carter choke, choke, question
I'm thinking about switching over to a manual choke machinereplica Drivetrain 16 04-22-2010 04:44 PM
choke cable holley carb.... derekcj5 Drivetrain 12 03-19-2010 07:27 PM
Choke plate rod screw broke cdlongjr Drivetrain 1 04-19-2009 01:17 PM
Need help w/electric choke cdlongjr Drivetrain 2 04-10-2009 04:49 AM
