Carb swap?This is a discussion on Carb swap? within the Drivetrain forums, part of the CJ Forums category; Do you think this would be a good upgrade from my holley 2 bbl 300 cfm carb?
600 cfm too ...
Carb swap?
03-10-2010, 04:06 PM
Vehicle(s): 77' CJ-5, 360 c.i. motor, T-150 trans, D-20 transfer case, Dana 30 front, A.M.C. 20 rear w/ 4.10's & trac-lok
600 cfm too much? not a reliable carb? Just ran across it on C.L.
EDELBROCK Chevy Carb
Thanks, Bushman
77' CJ-5, 360, Cam, Intake, Headers, H.E.I., Holley carb, Solid axles, an' plenty custom welded goodies
Re: Carb swap?
03-10-2010, 04:24 PM
IMO it would be to much.
found a link to figure what size you need. http://www.summitracing.com/expertad...rygroup=Howtos
 .. http://www.orfw.org/
Reason: added link
Re: Carb swap?
03-10-2010, 06:52 PM
Vehicle(s): 83'CJ-8 Scrambler Slightly Modified;), 67'Jeep M-725, 88'YJeep Wrangler Slightly Modified;)
a 600 CFM vacuum secondary carb will work, but a 470 CFM would be better.
Re: Carb swap?
03-10-2010, 07:10 PM
Thanks for the link- it looks like the 470 would be the way to go but the chances of finding a used truck avenger around here that I can afford- if at all- are pretty slim. do you think the Edelbrock 1404 500 cfm would still be too much? I may have better luck finding one of those.
thanks - Bush
Re: Carb swap?
03-10-2010, 07:28 PM
thanks - Bush
IMHO 500 CFM would be fine.
I've been running Holleys since I started out, I don't have anything against the Carter AFB/ Edlebrock performer. I just don't have any experence.
