carb questionThis is a discussion on carb question within the Drivetrain forums, part of the CJ Forums category; trying to get a rebuild for my carb. Seems the PO put an older MC2100 on and I've having trouble ...
carb question
03-08-2010, 12:16 PM
Vehicle(s): 88 Ford F150, 78 Jeep CJ7. 73 Jeep CJ5
trying to get a rebuild for my carb. Seems the PO put an older MC2100 on and I've having trouble finding the part number to order a kit. only numbers i can locate are near the bottom front. Can someone tell me if this is the number im looking for?
Re: carb question
03-08-2010, 01:07 PM
Vehicle(s): 1978 Cj-5 1982 Cj-8 1985 Cj-7
Is this on a 8 cyl.? I think it is. Going by that the V-8s had the motorcraft carb on them already. You should be able to order one from Napa. Its a popular swap on the I-6 and most times comes from a Ford that had the smaller 1.08 venturi's. That # your showing looks to be on the plastic adapter / gasket plate and won't get you anywhere. There should be a tag on it somewhere but often times these are gone on a 30 plus year old Jeep. Look for numbers on the carb body itself. I'll check around mine when I get home and see if I can find anything for you.
Re: carb question
03-08-2010, 01:42 PM
unfortunatly the plate is missing. I'll start disassembling it tonight and hopefully be able to find a number on it. if not, can i just order a universal rebuild kit for the 2100 somewhere?
Re: carb question
03-08-2010, 02:10 PM
Modded Jeeper
Vehicle(s): 1978 CJ7 258 w/ smog equip. removed, Autolite 2100 carb swap, Summit Racing street & strip ignition and coil, Optima yellow top, Flowmaster 40. Dana 30 front w/ Warn lock-out hubs, T-18A trans, Dana 20 t-case, AMC 20 rear. Everything else is stock, except the driver who is highly modified.
NAPA part #2-5585
1978 CJ7 golden eagle
Re: carb question
03-08-2010, 05:01 PM
Vehicle(s): '73 CJ5 232/T14/D20/D30/D44,
'74 CJ5 Renegade 304/T15/D20/D30/D44,
'85 CJ7 258/T5/D300/D30/AMC20
No numbers stamped on the front or rear surfaces of the air horn?
-- Tim --
