Default Auto Transmission
Old 09-06-2012, 10:37 PM   #1
metcage is offline
metcage
Rep Power: 0 metcage is on a distinguished road
Has any one changed a stick shift to an automatic in a cj5, and how big or bad a job is it?
Default
Old 09-06-2012, 11:06 PM   #2
Rep Power: 14 gert is on a distinguished road
Big....... You need everything for whatever auto tranny you pick including bell housing and transfercase adapters depending on what you pick plus tranny mounts oil cooler shifter and drive shafts
Default Re: Auto Transmission
Old 09-07-2012, 12:12 AM   #3
Saddle Tramp is offline
Saddle Tramp
Rep Power: 9 Saddle Tramp is on a distinguished road
In general, automatic transmissions are too long for a CJ5; your rear driveline will be too short.
The Following User Says Thank You to Saddle Tramp For This Useful Post:
metcage (09-09-2012)
Old 09-07-2012, 04:31 PM   #4
^^ what he said, that's why jeep only used autos in cj7's. and 8's.
The Following User Says Thank You to Old Dog For This Useful Post:
Old 09-07-2012, 05:29 PM   #5
Torxhead is online now
Rep Power: 11 Torxhead is on a distinguished road
Here's one that has a 700R4 and a Chevy 350. Although it has 2 reversed 9 inchers to accomodate the driveshafts.
The Following User Says Thank You to Torxhead For This Useful Post:
Old 10-29-2012, 05:55 AM   #6
micrablue is offline
micrablue
Vehicle(s): 1. 85 CJ-7 (Black&Tan) 2. 85 CJ-7 (Beach Yellow&Black)
micrablue's Avatar
Images: 12
Rep Power: 0 micrablue is on a distinguished road
Metcage, did you decide what you are going to do?
I own 2 CJ-7's; both have engine, trans, and axle swaps, and both are road trip worthy.
My current project is swapping an automatic in my black one, which currently has an NV4500. I am not sure about a CJ-5 drivetrain, but I can say my rear driveshaft is pretty short and my front driveshaft is lengthened. I would say you should be able to do this swap to a CJ-5, taking into account:
- Using CV joints for both driveshafts
- Limiting amount of lift
- Perhaps using a Ford 9inch high pinion rearend (I use this) at least
good luck!
Old 10-29-2012, 09:16 AM   #7
NorthwestCJer is offline
NorthwestCJer
Vehicle(s): 1984 CJ7 D30 4.10's locker, M20 4.10's one peice axles locker, 258 with MC2100 and K&N, Nutter bipass, 8mm wires, Or-Fab cage, Tuffy console, Bestop seats, GM power steering, 4 inch Rancho lift, Edlebrock shocks, On board Air, Smittybuilt winch bumper, M8000 Warn, 10k Synthetic, Swing tire carrier with Hi-Lift, extra fuel, shovel, chainsaw, 33" KM2's on 8 inch rims, Bestop Super Top!
NorthwestCJer's Avatar
Rep Power: 7 NorthwestCJer is on a distinguished road
Lots of CJ5's and Flaties have autos. I trail run with many that have swapped the stick for an auto.
The setup will matter, to wich year and drive train you are running. Pre-72 will have a Spicer 18 T-case that is offset and lower down on the rear output shaft. This helps for drive line angle issues.
If after 1972, you can get a CV (double joint) rear drive shaft and it will take care of the issues.
Also, many have swapped in V6's/I4's and move them farther forward to compensate for the drive line issues.
Yes, it can and has been done by many!
Member of Spokane 4 wheelers and Yakima Jeepin Nomads. Member of PNW4WDA
Default
Old 10-29-2012, 11:00 AM   #8
Kilo19 is offline
Kilo19
Vehicle(s): 07 ford f-150 xl, auto, daily driver 98 chevy suburban, (family car)(SOLD) 2005 Ford Expedition 80 cj-5, body and frame
Kilo19's Avatar
Images: 15
Rep Power: 6 Kilo19 is on a distinguished road
Mircrablue. U gonna be using the nv4500? I'm looking for one in mine, gonna bolt to a 350
check out my progress (slow and steady)
MY POS TO RUNNING/READY BUILD
Old 11-07-2012, 12:07 AM   #9
dabbrowne is offline
dabbrowne
Vehicle(s): 1973 CJ5 (AMC 1976 360 5.9L rebuilt) V8 Edelbrock Weber 1406 4 barrel carb with TorqueFlite 727 Auto transmission, 31" tires, Dana 30 Front Diff, Dana 44 Back , Dana 20 T case.
dabbrowne's Avatar
Images: 24
Rep Power: 6 dabbrowne is on a distinguished road
Hello
I just bought an 1973 CJ5 with a 304 and a Automatic Transmission. However it is not stock and I do not know what type it is. It seems to run fine except for the 4X4 shift (moves around - not clear three positions) is very sloppy. Seems to be a 4X4 that is all the way forward, and 2WD in the middle and neutral all the way back. Here are some pictures. If anyone can tell me what kind of Transmission it is that would be great. Also you can see how short the drive shaft is so the Auto trans has room.
Old 11-07-2012, 10:02 AM   #10
BC CJ is offline
BC CJ
Vehicle(s): Early 1975 CJ 5 304, NP435, AA, D300, D30, D44
Rep Power: 7 BC CJ is on a distinguished road
Originally Posted by dabbrowne View Post
Hello
As I dont see any adapter plate to the 304 I'm going to guess that is a TF727 from a full size Jeep. I think the trasfer case is a dana 20... (edit: My mistake - Dana 300 behind the tf727) my shifter is sloppy in the same way you describe yet works fine. I'm not sure if thats just how they are or if it's an old, worn out thing.
Congrats on the new Jeep.
Any more pictures of the rear driveshaft? How much lift do you have? If I'm correct about what units are under there it is a swap I may consider; if it works fine in your 73 should work in my 75
auto , transmission
YJ Auto or 5speed? Az84cj7 Jeeps other than CJ's 3 11-13-2011 04:02 PM
Manual vs. Auto Jeep Transmission Im Not Spam Jeep News and RSS feeds. 0 04-21-2011 07:00 PM
1977 CJ7 Auto transmission rolls when in Park eayres Drivetrain 4 03-30-2011 02:19 PM
cheroke 4l auto to cj ?? essexmo Drivetrain 10 02-16-2010 12:45 PM
auto trans bigpapa Drivetrain 0 11-09-2009 12:17 AM
