Default AMC code is confusing me
Old 03-04-2012, 04:06 PM   #1
Kimball is offline
Kimball
Rep Power: 0 Kimball is on a distinguished road
So I bought a CJ7 and it's supposed to be a 79 with a straight 6. I wanted to put in a new clutch kit so I looked on the block and read the build code. 910A08. It has a t176 married to a Dana 300. I'm thinking its a 79, October, 1 bbl 258, eighth day, but the 9 indicates it being 67 or 76 because it wasn't until 80 they used the last digit of the year right? I bought a clutch kit for a 79 and the through out bearing doesn't fit over the tranny's shaft. It also connects to the fork differently than the one I removed. The old one had a square plate with two clips. The guy I bought the jeep from said he had a clutch job done on it but it never worked after that. Its looking like his mechanic had the same problem as I. Help I need a clutch kit that fits!
Last edited by Kimball; 03-04-2012 at 04:23 PM.. Reason: I left out the transmission type
Default Re: AMC code is confusing me
Old 03-04-2012, 04:59 PM   #2
Al Lindner is offline
Al Lindner
Vehicle(s): 1980 CJ 7 258 CID T176 2004 F-150
Rep Power: 8 Al Lindner is on a distinguished road
Two different size clutches came in that year with the 258CID 10.5" and 11" Dont know why. maybe you have the wrong kit??
Old 03-04-2012, 11:15 PM   #3
Saddle Tramp is offline
Saddle Tramp
Rep Power: 10 Saddle Tramp is on a distinguished road
If a 1979 CJ7 your VIN should be : (J)(9)(A, F, or M)(93)(A or E)(A) then 5 sequential serial numbers
A 1979 CJ was only offered with a 3 speed T150 or a 4 speed T18 with a Dana 20 transfer case so your tranny and transfer case are a transplant. In 1979 either a 10-1/2 or 11 clutch will work.
Check out this VIN decoder:
http://www.jeepfan.com/tech/decoding-jeep-cj-vin-numbers-1971-1986/
The Following User Says Thank You to Saddle Tramp For This Useful Post:
1986cj7 (03-09-2012)
Old 03-05-2012, 04:54 AM   #4
Kimball is offline
Kimball
Thanks for the replies. The vin # shows it being an 80. I thought it was a donor body because of the amc build date on the engine block. I'll do some more research. I'm new to jeeps and I'm having a blast!
Old 03-05-2012, 12:29 PM   #5
Saddle Tramp
The engine build date is always before the vehicle assembly date for obvious reasons so it is not uncommon for the motor to have been built the year before the model year. 1980 is the first year of the T176/Dana 300 combo and is the last year the AMC 304 was offered in a CJ.
Old 03-08-2012, 08:11 PM   #6
Kimball is offline
Kimball
After some research I've determined that the tranny is a T177 and the transfer is a Dana-300. What would be a good clutch?
Old 03-09-2012, 12:20 AM   #7
Saddle Tramp
The T177 was never used in a CJ as the input shaft would be too long; it was only used in FSJs. Most likely you have the original T176 as a T177 with a CJ shaft would be a T176.
Old 03-09-2012, 05:07 AM   #8
Kimball is offline
Kimball
There is a metal tag riveted to the tranny that has a few #'s on it and one of those #'s is 5359389. I read somewhere that those #'s were for a 177 and a 176 would be 5359390. Is there ant truth to this? Thanks for all the input guys, your all a big help!
Old 03-09-2012, 09:53 AM   #9
1986cj7 is offline
1986cj7
Vehicle(s): 1986 cj7 258, t-176 4-speed, d-300, moser one piece axle in back in amc 20,G2 4.10 gears front and back, detroit truetac front and back,G2 4340 chromoly front axles in a d-30, 4" rough country lift, 33" tires
Images: 13
Rep Power: 8 1986cj7 is on a distinguished road
Thanks for the link I've been searching for this info for sometime, to see just what my jeep came out with stock, and now I know.
amc , code , confusing
Vin Code Help cworld Misc CJ Discussion 2 04-24-2013 09:55 PM
Im greenhorn. my questions will always be confusing CJB4POWERBILL Introductions 14 03-13-2013 07:51 PM
Engine Code Question thiswontbetooexpensive Drivetrain 7 11-30-2012 03:11 PM
ALl the infromation out there is confusing me thardy32541 Drivetrain 19 01-17-2012 05:27 PM
T-5 trans. 5th gear and Vin code jamesweed Drivetrain 5 04-25-2011 08:53 AM
