Default 258 engine hose setup on valve cover
Old 12-04-2010, 11:26 PM   #1
blkstx87 is offline
blkstx87
Vehicle(s): 1984 CJ 7 Renegade 258 6cyl
Rep Power: 0 blkstx87 is on a distinguished road
I am looking for the correct setup on a 84 258 valve cover. The front hole is the oil fill hole the middle hole is the pcv valve that routes to the carb, then in the back hole I have a push in style breather that smokes enough that it comes in the cabin enough to smell and see when the sun hits it right. Just wondering if it should be routed to the air filter breather or what. The breather cap is wet and it looks like there is a leak but it is nothing but where the smoke is coming out of the valve train. Any pics or info would be great. I am posting pics of my engine.
Last edited by elwood blues; 12-06-2010 at 09:39 PM.. Reason: click free pic :chug:
Default Re: 258 engine hose setup on valve cover
Old 12-04-2010, 11:35 PM   #2
73CJ is offline
73CJ
73CJ's Avatar
Images: 61
Rep Power: 11 73CJ is on a distinguished road
75s had a hose going to the air cleaner from the rear hole in the valve cover.
The Following User Says Thank You to 73CJ For This Useful Post:
blkstx87 (12-09-2010)
Old 12-05-2010, 12:33 AM   #3
dslywalker is offline
dslywalker
Vehicle(s): 1983 CJ7,258,stock Original Owner
Rep Power: 9 dslywalker is on a distinguished road
Mine used to go to the side of the air cleaner.Inside the air cleaner was small filter insert that caught the oil mist.It was always screwing up air cleaners with oil mist.When i put on fuel injection i went to the breather cap.Works okay for me anyway.Your breather cap might need cleaning or replaced also.PVC is in the right place.Maybe the PVC valve is needing cleaned or replace also to get the pressure out of the valve cover
Mike
The Following User Says Thank You to dslywalker For This Useful Post:
Old 12-05-2010, 08:00 AM   #4
dalefan88 is offline
dalefan88
Vehicle(s): 79 cj5 258, t150, dana 20 transfer case, dana 30 front, 20 rear,warn hubs,2.5" procomp lift,teamrush,msd box,mc2100 carb,hedman header,clifford intake,optima battery, ford shock towers.
dalefan88's Avatar
Images: 29
Rep Power: 11 dalefan88 is on a distinguished road
sounds like you need a new pcv valve and put a new breather on to. i have a after market breather on mine with a new pcv and i havent had any problems.
you cant fix stupid. Ron White
The Following User Says Thank You to dalefan88 For This Useful Post:
Old 12-05-2010, 10:00 AM   #5
Cheepjeep85 is offline
Cheepjeep85
Cheepjeep85's Avatar
Rep Power: 11 Cheepjeep85 is on a distinguished road
his motor probably has a little more blow by than others thats why he's getting the smoke. you can run a hose to the breather and send it back through the motor with no problems you just need to find a port on the breather to hook it up to. you might want to find a filter of some sorts to catch the oil if you have alot if not i wouldn't worry about it to much.
The Following User Says Thank You to Cheepjeep85 For This Useful Post:
Old 12-09-2010, 06:08 PM   #6
blkstx87 is offline
blkstx87
Thanks for the replies I am going to find new breather (any ideas where to buy) auto zone does not carry and new pcv. Also my dipstick tube has come off at the block ? Any ideas on repair, or do I have to replace with a new one, and if so how involved is it.
Old 12-09-2010, 06:23 PM   #7
Cheepjeep85
all you need to do is get a hose run it from where the little breather is to the engine air cleaner that is all you need to do to solve the smoke coming into the jeep. there should be a place you can connect it to. OR you can run a hose from that same hole down to the ground as a blow by tube like big trucks have. thats how mine was when i got it before the rebuild. NOW lets hear it from the green weenies about my last suggestion
Old 07-30-2011, 07:12 PM   #8
care729 is offline
care729
Vehicle(s): '83 CJ7
Rep Power: 0 care729 is on a distinguished road
I'm having this same problem, but I'm confused about why it is??
I'm a newb....
Old 07-30-2011, 07:34 PM   #9
the PCV is supposed to allow enough vacuum to the valve cover to cause a slight negative pressure in the crank case and suck out the blow by into the intake manifold to be burnt. the foam pad in the breather is to "filter " the air that is being drawn into the crank case by manifold vacuum. If the PCV is clogged it will not cause a negative pressure and if the blow by is too great it will cause a positive pressure at the filter which blows oil out into the world.
Old 07-31-2011, 09:37 AM   #10
Sasquach is offline
Sasquach
Sasquach's Avatar
Images: 35
Rep Power: 11 Sasquach is on a distinguished road
^^^^X2^^^^
Make sure the PCV is off a good vacumm source either from the intake manifold or a lower carb plate port.
258 , cover , engine , hose , setup , valve
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Weber 38 - water (condensation) in valve cover hose Flex BT Drivetrain 2 01-31-2013 05:42 PM
Valve cover Plenty Coups Drivetrain 7 01-28-2013 06:16 AM
Elbow for valve cover air intake from engine air filter? go85cj7 Drivetrain 1 06-02-2011 04:11 PM
Getting valve cover off Kevinp Drivetrain 8 02-22-2010 11:09 AM
valve cover. jwill22 Drivetrain 3 05-21-2009 04:32 PM
