| Suspension and Steering Suspension, Steering, Tie Rods, Drag Links, Coil Overs, Lift Kits, Shocks and more... |
tilt wheel in 77 CJ5 projectThis is a discussion on tilt wheel in 77 CJ5 project within the Suspension and Steering forums, part of the CJ Forums category; This was the first Saturday it didn't rain/snow/freeze or something so I went to the pull your part looking for ...
02-21-2010, 01:14 AM
Vehicle(s): 1977 cj-5
4.2 2bbl carter "upgrade".TFI ignition with MSB6 offroad module,CS144 140 amp RPS alternator with remote regulator T-150,d-20,Amc20. D-30,
skyjacker 2.5 lift?nitro shocks,31" BFG A/T off road.
1981 J-10
4.2 with 4.0 head and 3 angle valves, headers, T177, NP208, AMC20 wide track with factory one piece axles. D44 front.
This was the first Saturday it didn't rain/snow/freeze or something so I went to the pull your part looking for a new steering column. And I found one in a 92 Cherokee with a auto floor shift and no cruse. This looks like a walk in the park to mount, the only problems I have encountered so far is the difference in the shaft clamp and the little pin that will not let you remove the key if it is not in park. I don't see these as being any real obstacle.
I put it in for a test fit and took a few pictures, It really isn't that purple, I am hoping I can paint the plastic with something to make it a bit more presentable than blue. And the really amazingly amazing thing about this column from a pull your part junk yard was that it had a key in it!!  What are the odds?? I may have to find another wheel, it looks like someone already took a bite out of this one.
that was going to cost me some major bucks to have the switch picked and replaced. now it's not a problem, I guess this is one of the temporary perks to the cash for clunker program.
The secret to flying? just throw yourself at the ground. and miss.
Re: tilt wheel in 77 CJ5 project
02-21-2010, 08:04 PM
Vehicle(s): 1978 Jeep CJ5, 2581v, t-18, t-20, amc 20, dana-30,
1964 CJ3B, 4-134
IO I am color challanged for sure but even I can see clash there  .
I used a 2 part epoxy paint on my Jeeps body and made tests on dif. materials like plastic and such and it stuck to everything and had good flex too.
 1978 CJ5, 258 w/TFI, T-18, D-20, detuned Rubicon 4.5", Warn full float model 20 rear w/locking hubs, 31x10.5 on factory steel 15x8's
02-22-2010, 12:26 PM
1981 J-10
I think the quartz halogen work light may have something to do with the color in the picture but I will check out the epoxy paint, I think black will look a lot better unless I can find a red wheel.
A couple of shots of the new and improved steering shaft.  I put a 4 inch section of the unused male shaft in the splice to keep it aligned and add a bit of rigidity beveled the joint and TIG welded the sections together to make a new shaft the same length as the original CJ shaft with the end clamp from the Cherokee.
I was mistaken about one thing, the steering column from the CJ and the Cherokee are the same length.
02-22-2010, 09:57 PM
Vehicle(s): my rides 1983 CJ7 1996 chevy cavilier 1987 jeep cherokee 1980 Rolls Royce Silver Shadow 1961 series 1 E type Jaguar convertable 1960 land rover
there are vinyl paints you can buy to change the color I would think the steering wheel would be leather though so that may require a dye the trick is getting it totally clean first then painting it
Guns dont kill people !! Husbands that come home early kill people !! The guns just a handy tool
03-11-2010, 11:50 PM
1981 J-10
The new tilt wheel is in the CJ, much thanks to Rush power systems for blazing the trail. I do have to sort out the windshield wipers and washer but I don’t think this will be a problem, it is really cool to have the high beam switch on the column.
Now for the only issue I have with my project and the topic I would like some opinions on.
The steering shaft, not the column but the shaft with a u joint on both ends that connects the column to the steering actuator, had to be modified. I don’t think I have taken any liberties with safety or the system integrity in any way but for some reason I had really wanted to do this without cutting and welding. Specifically, I cut the top u joint from the XJ shaft and welded it on to the CJ shaft after cutting the top of the CJ shaft off. There was no way the CJ u joint was ever going to fit the XJ column.
The XJ also had an arrangement that allowed a lot of play in the shaft, about 5 degrees I would guess, which was totally not going to happen. So I welded this also. I now have the slider for the extension of the shaft but axially it is totally ridged.
Now, the question, Is there something wrong with modifying the steering system in such a way, morally, mechanically, aesthetically, legally?
03-12-2010, 01:41 PM
You didn't really do that did you.
No really I don't see where it would hurt anything, but I would want mine to be able to slide for flex in the frame.
Legally, I don't know. Maybe, depends on how good the lawyer is.
 .. http://www.orfw.org/
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
tilt wheel
cjnewbie |
Chassis and Body |
15 |
02-15-2010 11:43 PM |
Tilt front end
7D8CJ |
Chassis and Body |
4 |
02-12-2010 09:51 AM |
tilt steering wheel
IOPort51 |
Suspension and Steering |
21 |
12-13-2009 09:07 PM |
Lost a wheel
shamrock |
10 |
08-09-2009 12:07 AM |
wheel joint?
dalefan88 |
Drivetrain |
18 |
06-14-2009 09:48 PM |
