Default Steering column swap
Old 11-14-2011, 09:05 AM   #1
Firejunky is offline
Firejunky
Vehicle(s): 75 CJ5 Renegade, 304, 3speed trans, stock
Rep Power: 0 Firejunky is on a distinguished road
I got a 75 cj5 and was wondering which steering column I could swap to shorten and possibly put a tilt in.
Default Re: Steering column swap
Old 11-14-2011, 11:16 AM   #2
SrBeaver is offline
SrBeaver
Vehicle(s): 82 Scrambler, Going back to factory configuration ^Currently^ blown up 304 in the bed, T18a, twin stick 300, D30 front and Currie 9' rear 4.11 gears. 72 CJ 5 turin into rock buggy (Possibly 440 powered)
Rep Power: 8 SrBeaver is on a distinguished road
I've heard of guys using an Astro van column in CJs I have not personally done it but it is a pretty straight forward swap from what I'm told.
Currently Serving or a Veteran of the US Military, Own a Jeep vehicle, come join us at,
Militay Jeepers
Old 11-14-2011, 10:23 PM   #3
Firejunky
Thanks SrBeaver I'll look into that
Old 11-14-2011, 10:53 PM   #4
jeepboy45 is offline
jeepboy45
Vehicle(s): 1979 CJ-7, Newly rebuilt AMC 360!, fully rebuilt GM TH400, Quadra-trac TC w/Milemarker 2x4 conversion, AMC mod 20 rear w/1 piece Moser axleshafts, mod 30 front w/tie rod flip and castor correction shims, 4 in lift, Centech complete wiring harness, dual electric fans on 3 core aluminum radiator, tilt steering wheel, 20 gal poly gas tank, new J20 steering box, MSD 6A ignition combined with TeamRush distributor mods
jeepboy45's Avatar
Rep Power: 7 jeepboy45 is on a distinguished road
I put a waggy tilt column in my 79 CJ7....It was a direct bolt up, right down to the wiring harness..easiest swap in history.
However, it wont give you a shorter column.
The Following User Says Thank You to jeepboy45 For This Useful Post:
nivensid (06-06-2017)
Old 11-15-2011, 08:01 AM   #5
Firejunky
This is my first jeep restoration. Where would I find a waggie?
Old 11-15-2011, 08:16 AM   #6
Images: 219
He means a Jeep Wagoneer - check most junk yards.
Google Search - Jeep Wagoneer
Old 11-15-2011, 08:21 AM   #7
jeepboy45
jeepboy45's Avatar
"waggy"....short for wagoneer...
Call junkyards in your area. Or better yet, go to www.car-parts.com
You can do a search for yards nationwide. Not all yards put their vehicles and parts in this database, but it is a good resource. I usually start on the phone with a local yard or two at the same time utilizing that web site.
I dont know the dimensions on CJ5's... I would "assume" the lenghts of columns, and "dash-to-firewall" distances are the same as a CJ7, but I dont really know.
"BusaDave9" and "CJ" are walking databases for CJ5 info. Maybe one, or both will see this and give their imput....or try and PM them. (private message)
I've heard of others using GM columns out of camaros, firebirds, etc, but the threads I have read seem to be filled with issues of compatibility and fabrication. When I did mine, I was ALL ABOUT the direct swap... So I know there are columns out there you can use, it was just logical to me to keep it Jeep, and all mounting brackets, wiring harnesses were left untouched.
Good luck...
Old 11-15-2011, 08:22 AM   #8
jeepboy45
jeepboy45's Avatar
CJ, you beat me to it by about 5 minutes!!!
Old 11-15-2011, 09:23 AM   #9
Firejunky
Thanks for all the info everyone.
Old 11-15-2011, 09:35 AM   #10
SrBeaver is offline
SrBeaver
how far are you from Savannah? I was at Cash N Carry a couple months ago and the had an 85 waggy there had column in it then.
Militay Jeepers
column , steering , swap
74 CJ5 steering column change out to a tilt steering column BREW Suspension and Steering 9 05-10-2014 10:17 PM
Cruise control from YJ/XJ steering column swap Bucks86Renegade Body, Electrical, Chassis 3 10-12-2012 12:09 AM
steering column swap tmkyle Suspension and Steering 9 12-18-2010 07:01 PM
steering column swap don ahlers Suspension and Steering 2 05-14-2010 07:51 AM
CJ 5 steering column swap. rushpowersystems Suspension and Steering 10 02-08-2010 10:25 PM
