Default Steering box/rebuild or replace
Old 08-16-2009, 03:15 AM   #1
catman is offline
catman
Vehicle(s): cj7 1986, built from three others.
catman's Avatar
Rep Power: 0 catman is on a distinguished road
I just got my first CJ...not my first jeep, but different than what i'm used to. The steering box, is completelly covered in oil. and I have a box kit with all the parts it should take to rebuild it. Having had a look at the following link...
Saginaw Steering Box Rebuild - Four Wheeler Magazine I'm not sure if its a job I should take on. Is it a common sence type of teardown and rebuild...or would I be better off replacing it...mine is a power steering box.
I hope that makes sence?
ED
Default Re: Steering box/rebuild or replace
Old 08-16-2009, 07:09 AM   #2
coldwater is offline
coldwater
Vehicle(s): 04 Grand, Dodge 2500 CTD, 78 CJ7
coldwater's Avatar
Rep Power: 11 coldwater is on a distinguished road
Hi catman, and welcome to our site. I personally do not recommend rebuilding a steering box.Their not as easy as they look to do a rebuild on, and are pretty tricky. A rebuilt unit is not very expensive, and it's a guarantee that it was done right. Why fool with a part that can end up killing you.
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf."
-- George Orwell
Old 08-16-2009, 07:52 AM   #3
mylittlecj5 is offline
mylittlecj5
RIP Mike, we'll all miss you
mylittlecj5's Avatar
Images: 9
Rep Power: 12 mylittlecj5 is on a distinguished road
^^X2. I went thru this exact same thing recently. After looking into it, I realized that it wasn't something for a shadetree mechanic to fool with.
I am headed out to the garage to install my brand new variable rate PSC power steering box in just a few minutes!
PSC Motorsports
Old 08-16-2009, 04:10 PM   #4
catman is offline
catman
catman's Avatar
Whats with the morbid thought??....
There is no one getting hurt by asking questions.
The rebuild is something that I'm sure I can do, BUT....some things should be left to professionals. That is why I ask fellow Jeepers with knowledge, so that just when you are going to "give-ER" that little voice yells "wOOOOOOW'...LOL
Thank you, sounds like good advice.
I've had lots or repairs done in the past (To XJ's)and later found out that I could have done it myself for less, and would of had fun enjoying the knowledge.
But since I must replace it, any advice on an upgrade that does not cost an arm and a leg?
Old 08-16-2009, 04:23 PM   #5
coldwater
coldwater's Avatar
Kind of depends on if you just want to keep it pretty stock with reasonable tire size, or if you want to lift it hang big meat on it, and wheel it. A stock box is a pretty rugged little unit, and they have served me well over the years. Some guys like the aftermarket units, like dalefan, that went to a PSC box. You can get a reman to pop right in for (I think) under a hunderd bucks. There's not much I wont tear into myself, but some things are just not worth it. Steering boxes are top on the list, and i never bother with stuff like master cylinders, clutch cylinders, and the like. Their just too cheap to buy and replace.
-- George Orwell
Old 08-16-2009, 04:51 PM   #6
catman is offline
catman
catman's Avatar
Yup...been doing some reading and for what I see a straight replacement should be good enough...they are apparently strong little units....In the Great White North, thou, parts are not as available or inexpensive as in the States. Thank you I will look for a rebuilt(proffesional) unit and do a straight exchange.
Old 08-16-2009, 05:01 PM   #7
kicknjeep is offline
kicknjeep
Vehicle(s): 1999 TJ, 1976 CJ-5 2 seater
kicknjeep's Avatar
Images: 20
Rep Power: 10 kicknjeep is on a distinguished road
I just replaced seals on mine and I would have to say I do not want to have anything to do with a full rebuild. Isn't there a good upgrade that will bolt right in like a Waggy box? does anyone have a link to a write up on this?. After all not everyone can afford a PSC box
Old 08-16-2009, 08:49 PM   #8
mylittlecj5
Images: 9
The Waggy boxes are supposed to have bigger ports and I think some have Variable ratio like my new one, But they are scarce around these parts. I looked for 2 months before I finally sold my little boat and got this PSC box.
Old 08-17-2009, 06:30 AM   #9
Images: 219
I just stuck a box of an early model Malibu (I know it was an intermediate GM) that had the same ratio. I has worked for years...
Old 08-17-2009, 11:08 AM   #10
kicknjeep
kicknjeep's Avatar
Images: 20
hey CJ did you use stock input shaft from the steering column? same question for the pitman arm.
box or rebuild , replace , steering
dana 30, rebuild or replace ? jamesdaniel Drivetrain 9 08-25-2012 08:31 PM
need to replace steering box nanasjeep Suspension and Steering 4 11-08-2011 05:33 PM
Replace Steering Column??? beking Suspension and Steering 8 01-03-2010 07:48 PM
To rebuild or replace...... stevenalex Drivetrain 8 08-22-2009 02:18 PM
Rebuild, Replace or Upgrade 23hasyourback Misc CJ Discussion 7 03-19-2009 07:44 PM
