Default QUICK DISCONNECTS... question
Old 03-09-2010, 12:13 PM   #1
SANDBLASTER is offline
SANDBLASTER
Vehicle(s): CJ-7 258 inline six,4speed ,AMC 20/30diffs,331 gears FRONT AUSSIE LOCKER,BDS 3 INCH SUSPENSION LIFT, 33X1250X15 BFG AT'S
SANDBLASTER's Avatar
Rep Power: 1 SANDBLASTER is on a distinguished road
OK I installed a lift and then new JKS quick disconnects .
I had to pull down on the passenger side about 1 inch to get the disconnect pin in ... but not on the drivers side.
WHAT YALL THINK ??? Will It be ok and adjust after driving or what ???NOTE: the drivers side shackle is slightly twisted ?
Default Re: QUICK DISCONNECTS... question
Old 03-09-2010, 12:47 PM   #2
Vehicle(s): 1983 cj7,1985 Dodge D250, 1971 Dart
Images: 27
Rep Power: 3 gert will become famous soon enoughgert will become famous soon enough
sounds like the driverside of your jeep sits lower by 1 inch. I guess it would come down to bresking out the tape measure to get some numbers and find out for sure....Do you want to do something about it? I would think worn bushings/sagging springs/tire wear/slight twist in the frame/unlevel ground could be possible culprits. I had a similar prob with my buddies YJ I didnt think much of it at the time as iI didnt have to move it far to get it to link up.
Old 03-09-2010, 01:09 PM   #3
Old Dog is online now
Images: 47
Rep Power: 4 Old Dog is on a distinguished road
It's a pretty common problem to have to pry one side to get them connected. If your not on flat level ground they can be almost impossable to connect.
.. http://www.orfw.org/
disconnects..., question, quick
Quick h.e.i. ? Petescj Drivetrain 19 11-03-2009 09:32 AM
Quick steering Question susie Suspension and Steering 40 05-05-2009 12:30 PM
Quick question about the T176. MadMax Drivetrain 11 03-26-2009 12:06 PM
