Default Powersteering Conversion
Old 11-04-2011, 06:45 PM   #1
The Odd One is offline
The Odd One
Vehicle(s): 1967 CJ5 302 stock,
Rep Power: 0 The Odd One is on a distinguished road
Hello,
I would like some help on doing a conversion from manual to power steering on my 1967 CJ5. I'd like to know what Jeep I can use for the swap. Any and all help is appreciated.
Default Re: Powersteering Conversion
Old 11-04-2011, 11:52 PM   #2
johnbilt is offline
johnbilt
Vehicle(s): 1973 CJ5 - AMC360 /EB Performer intake / Isky Cam / Holley Carb - T18 - D20 w/2.41 Low - 4.56 Locker Rear and Front Pwr-Lok.
Rep Power: 8 johnbilt is on a distinguished road
When I converted my 73 cj5, I bought a used box at a swap meet. It is basically a saginaw box, but came from a jeep. I also picked up a power steering pump from an AMC V8 to fit my motor and then purchased the factory lines to connect the pump. I think I also had to put an adapter or fitting onto the steering shaft.
You may want to contact partsmike.com for specific applications for your cj. He is a real nice guy down in Northern California with the right info and often carries many of these parts for a good price. I have dealt with him on several items over the years.
Good Luck
Old 11-05-2011, 07:23 AM   #3
mylittlecj5 is offline
mylittlecj5
RIP Mike, we'll all miss you
mylittlecj5's Avatar
Images: 9
Rep Power: 13 mylittlecj5 is on a distinguished road
your 73 came with a saginaw box originally for power steering. His Jeep should have a Ross steering system, which requires fabrication work to install power steering.
To the PO, How much fabrication work are you willing to do? I am unaware of any bolt-on applications to install PS on a Ross-equipped Cj.
Old 11-05-2011, 12:52 PM   #4
The Odd One
How much fabrication are we talking about it might be way out of my league. But I'll do what I can, this is my first jeep and really looking forward to getting it on the road.
Old 11-05-2011, 01:37 PM   #5
canuk is offline
canuk
Vehicle(s): !966 CJ5 / 2.5 lift/1' body lift BFG 33X12.5X15 tires Dana 20 Xfer / Flanged centered Dana 44 rear diff Herms Steering, 11' drum brake conversion.Hydraulic clutch,hanging pedals
Rep Power: 0 canuk is on a distinguished road
Might want to try Herms setup, i have and it works great.
Bolt on with one hole drilled into the frame.
Herm The Overdrive Guy
I have pic if needed.
Terry
Old 02-14-2012, 08:52 AM   #6
KeyLargoKen is offline
KeyLargoKen
Vehicle(s): 1969 CJ-5 "Dauntless" V-6 R.I.P. 1980 CJ-7 R.I.P. 1978 CJ-5 Golden Eagle
Rep Power: 0 KeyLargoKen is on a distinguished road
@Terry - are you running V6? I've been looking at Herm's setup and it looks to me like there may be some interference with the exhaust manifold. Can you post a pic?
Old 02-14-2012, 10:15 PM   #7
canuk is offline
canuk
Old 02-14-2012, 10:21 PM   #8
canuk is offline
canuk
http://i1009.photobucket.com/albums/...k/DSCF0002.jpg
http://i1009.photobucket.com/albums/...k/DSCF0003.jpg
http://i1009.photobucket.com/albums/...k/DSCF0008.jpg
http://i1009.photobucket.com/albums/...uk/Brakes2.jpg
Heres a few, if you need more let me know.
Regards
Terry
Old 02-15-2012, 06:26 AM   #9
KeyLargoKen
Thanks, I see you have outside the rail headers. The stock exhaust manifold is front dump and projects right where the steering gear is. I'm trying to decide between Herm's Kit and AA kit.
Red face Re: Powersteering Conversion
Old 03-19-2012, 08:01 PM   #10
existentialhandyman is offline
existentialhandyman
Vehicle(s): 1966 CJ6 Tuxedo Park Mark IV, 225 v6 3 spd on the floor, Front axel dana 27A, single lever 2 spd transfer
existentialhandyman's Avatar
Images: 14
Rep Power: 0 existentialhandyman is on a distinguished road
Send a message via MSN to existentialhandyman Send a message via Yahoo to existentialhandyman
My first jeep as well & I'm kinda in the same boat rowing the other direction. my 66 6a TPM4 came with such a conversion - kinda. PO had the saginaw box mounted on top of the frame just in front of the grill, behind the bumper. Body at firewall & grill cut to accept the column and assorted rods fabricated together. Exhaust manifolds were also modified/rewelded to a center drop to the rear and of course leak. l looked at the pics in the thread here and it is a nice clean job. I live where a heater in not an option and the headers may or may not fit. I dono.
I was thinking of trying to go back to stock but wonder why as I have yet to find someone that would advise this.
I keep wondering why NOT to go back to stock?
Thoughts, Guys?
Both my front end guy and myself think current setup is a bit squirrely with a good deal of correction needed at low(er) speeds and I'm not really feeling the PS thing anyway. the AA setup looks like it sits more like Herbs only in front of the crossmember , that has to be notched and an additional one added. Experience is a great teacher - on this Jeep I have so little.
conversion , powersteering
CJ 7 SBC Conversion Lightnin 1 Drivetrain 27 05-07-2014 02:20 PM
powersteering pump CJ5 V8 Coast Classics Misc CJ Discussion 2 04-09-2011 12:22 AM
4.3 V-6 conversion 81laredo Drivetrain 16 01-11-2011 10:04 PM
crappy headlights?? h4 conversion or hid conversion biohazard cj Chassis and Body 6 12-14-2009 08:54 AM
v-8 conversion davidyoungdoff Drivetrain 9 05-28-2009 05:54 PM
