Default Pitman Arm Nut
Old 08-27-2011, 10:28 AM   #1
grico777 is offline
grico777
Vehicle(s): 1976 CJ-5, 258ci, 3 speed, off road only, 2002 Jeep Liberty
Rep Power: 0 grico777 is on a distinguished road
Just finished replacing the gear box on a 76 CJ-5. Man what a job! The nut for the pitman arm to the gear box was worn so I had to replace it. After searching just about everywhere, I got a nut that fit at Napa for about $2.00. If you ask them for the specific nut they won't have it but they matched the one I had and it worked! Now that I have everything together the power steering belt seems too big and I can't find any way to adjust it. Any advice would be appreciated.
Default Re: Pitman Arm Nut
Old 08-27-2011, 10:53 AM   #2
Purple77CJ7 is offline
Purple77CJ7
Vehicle(s): 1977 CJ 7; Amc 401 .30 over, Howell TBI, modified Dana 20 with Terra Low gears and twin sticks, NV 4500 5-speed, modified Dana 30 and Amc 20 both with 4.56 gears (narrow track), ARB air lockers front and rear, SSBC rear disc brake conversion, MICO Brake park brake, Navaho brake booster/ master cylinder, PowerTank CO2 tank.
Purple77CJ7's Avatar
Images: 37
Rep Power: 8 Purple77CJ7 is on a distinguished road
There should be two 9/16 nuts on the back of the pump by the hoses to the pump, and a long nut in the middle that is 9/16. Loosen nuts and use center nut to rotate pump assemble towards fender to tighten belt. If there is no more adjustment left a shorter belt or new stock belt may be needed.
Old 08-27-2011, 03:41 PM   #3
Look at this picture. To adjust the PS belt loosen the 2 nuts circled in red. This will loosen the PS pump. Adjust the belt by putting a half inch ratchet into the square hole circled in blue. This will allow you to tighten the belt.
Purple77CJ7 talks about a long nut. I've had 2 CJ's but I don't remember ever having a long bolt. I had regular bolts but my open end wrench would slip and round off the bolts. There isn't enough room for a ratchet.
What I did was make my own long bolts. I bought a coupling nut and cut it in half with a hack saw.
I used each half as a long nut. You can see in my picture I now have plenty of room to grab the "long nut".
Old 08-27-2011, 06:04 PM   #4
Purple77CJ7
Images: 37
That's a good idea on the adjustment nuts, it is tight for wrenches. My pump does not have that bracket for a square drive. I have a long nut in between the two other nuts. It's welded I think to the back of the housing.
Old 08-28-2011, 08:38 AM   #5
Purple77CJ7
Images: 37
Sorry for confusion I should have post a pic earlier. Red circle is one of two retaining nuts, blue circle is my adjuster nut. I don't know if my pump is stock.
The Following User Says Thank You to Purple77CJ7 For This Useful Post:
grico777 (08-28-2011)
Old 08-29-2011, 06:56 AM   #6
grico777 is offline
grico777
Thanks for all the help. My pump adjusting nut was at a different location. at red arrow in the picture, but all the info I got gave me a hint where to look and I finally got everything together and working.
Old 08-29-2011, 07:58 AM   #7
Purple77CJ7
Images: 37
Glad you goter' done! Three different setups for adjustment. That's a jeep thing.
arm , nut , pitman
Pitman Arm mikemrq Suspension and Steering 2 10-28-2012 07:15 PM
GM or CJ pitman arm Capton Bill Suspension and Steering 5 04-13-2012 12:55 PM
pitman arm oldguy Suspension and Steering 30 02-27-2012 06:21 PM
Need a pitman arm stroked10 Suspension and Steering 15 10-02-2011 08:07 PM
pitman arm ? ga78cj5 Drivetrain 2 03-14-2011 06:48 AM
