Default Newbie, steering shaft removal
Old 01-03-2010, 09:51 PM   #1
CJ777 is offline
CJ777
Vehicle(s): 1977 CJ7, 2001 silverado, 2005 A4,41 F100,77 F350
CJ777's Avatar
Images: 5
Rep Power: 9 CJ777 is on a distinguished road
How do you remove the steering shaft ?
Default Re: Newbie, steering shaft removal
Old 01-04-2010, 07:20 PM   #2
Resident 'Old' Jeep Shaman
Images: 141
I do not think I have ever removed a shaft from a column before, I have replaced entire columns. Does Haynes or Chiltons have this info in them? I think that wold be the first place to look as they would have pictures and / or step by step instructions.
Old 01-04-2010, 11:26 PM   #3
CJ777 is offline
CJ777
CJ777's Avatar
Images: 5
I have the Haynes , but it basically just says to remove the the steering shaft. Not a hole lot of description.
Rolling with the punches
Old 01-05-2010, 12:27 AM   #4
maybe it's so easy it doesn't need an explenation?
Old 01-05-2010, 07:44 AM   #5
coldwater is offline
coldwater
Vehicle(s): 04 Grand, Dodge 2500 CTD, 78 CJ7
coldwater's Avatar
Rep Power: 11 coldwater is on a distinguished road
Remove the bolt from the upper shaft where it bolts to the column, and remove the bolt from the lower shaft at the steering coupling at the box. If you're living right, you can tap the coupling down enough to slip the splines off the shaft. If not, you may need to loosten the steering column to get enough wiggle room to get it out of there. Any time I have to do this little operation, while the shaft is out, I drill out the nylon crush pad heat up the shaft and pound it loose so It will just be a slip joint. Grease it up good before you put it back in, and It'll be cake If you ever have to do it again. If you can find another full shaft ( should be easy and cheap) do It to the new one, then unbolt the old one in the Jeep, and put the saws all to it, slide the new one in place, and save yourself a lot of grief.
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf."
-- George Orwell
The Following 2 Users Say Thank You to coldwater For This Useful Post:
CJ777 (01-08-2010), kmeyer (02-21-2010)
Old 01-06-2010, 07:53 PM   #6
CJ777 is offline
CJ777
CJ777's Avatar
Images: 5
Thanks,
Old 01-29-2010, 11:29 AM   #7
DHugg is offline
DHugg
Vehicle(s): '80 CJ7 304AMC crate with 8KMiles: MC2100 - AMC20 rear w/Superiors - Dana30 front - TF999 - Dana300TC - 35x12.5's - Tilt steer column - Flaming Rvr EZ-Steer Shaft - AGR Super Pump - AGR Super Box II - RockyRidge HD Brace - New home-designed digital TEMP - GAS - OILPR - CALIBRATE gauges.
Images: 46
Rep Power: 9 DHugg is on a distinguished road
I recently pulled the steering shaft from my '80 CJ7 304 w/ pwr steering. The shaft was rusted and wouldn't compress. I cut the upper swivel-joint on both sides - surprised how soft the joint bracket arms were - and took it apart.
BTW, the small cup-like bearings were turning only in rust-dust..... not a sign of oil anywhere.
The Following User Says Thank You to DHugg For This Useful Post:
kmeyer (02-21-2010)
Smile Re: Newbie, steering shaft removal
Old 02-21-2010, 05:31 PM   #8
kmeyer is offline
kmeyer
Vehicle(s): ALL? Not room- 84 CJ-7, 62 Willies Overland, etc.
Rep Power: 0 kmeyer is on a distinguished road
I think your rust comment just answered another question - thanks!
Old 08-19-2013, 11:55 PM   #9
truk820 is offline
truk820
Vehicle(s): 1981 CJ7, Iron Duke 151, SR4 transmission
Images: 2
Rep Power: 6 truk820 is on a distinguished road
Having trouble with taking out my column to get the tub off...any chance you have pictures to help me out?
newbie , removal , shaft , steering
Steering box removal TroyaCantrell Suspension and Steering 5 08-29-2012 11:12 AM
Steering shaft removal jarrettsvillejeep Suspension and Steering 8 07-27-2012 11:47 AM
locker instal- shaft/pin removal question rbagley Drivetrain 9 01-14-2012 09:53 PM
Steering COLUMN removal Tonyrod123 Suspension and Steering 0 10-10-2010 09:01 PM
drive shaft removal asphaltaddict Drivetrain 28 02-25-2010 09:33 PM
