A 2.5" lift will not require a dropped pitman arm, I don't think one is even made for such a small lift, and I would'nt worry about one till you go to a 3.5-4" lift. At 2.5" you will not experience bump steer. As far as shackles go, I would never advise using them to lift at all, but do recommend swapping to a heavy duty set in stock length. The originals are pretty wimpy, and prone to bending when used with lift springs. I personally use greasable shackles, as they improve the ride, and articulation. As far as hubs go, I like, and use the original heavy duty Warn units. They just work well. Dropping your trans and TC is a pretty good idea with a lift even as small as 2.5", because It's easy to do, and takes a good chunk out of the added angle from the new lift. 1" is plenty.
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf."
-- George Orwell
