Default CJ to Wrangler height conversion?
Old 03-09-2010, 10:31 PM   #1
Kane is offline
Kane
Vehicle(s): 1980 CJ5, 05 Colorado, 02 Aprilia
Kane's Avatar
Images: 5
Rep Power: 1 Kane is on a distinguished road
A stock wrangler has a flat spring, duh we all know that.
A stock CJ has some curve to it. duh again.
So what does a lift of 2.5 inches equal for a CJ if you were to use a wrangler lift spring? Because that arch would be different for each lift due to the difference in stock arch. Would a 4 inch wrangler spring equal a 2.5-3 inch CJ lift. Inquiring minds want to know.
Default Re: CJ to Wrangler height conversion?
Old 03-12-2010, 11:18 PM   #2
tdkask is offline
tdkask
Vehicle(s): 1979 CJ-5
Rep Power: 0 tdkask is on a distinguished road
I'd like to know this too. If a 4" CJ kit clears my 33's fine, would a 4" YJ kit have the same clearance? Or is a 4" YJ like a 2.5" CJ?
Old 03-14-2010, 05:42 PM   #3
LASTCJ786 is offline
LASTCJ786
Vehicle(s): 86 CJ7 258, T18, Scout 300,twinstick ,Dana 30 LS Dana 44 locker 3:73's,4"lift ,1" body.York OBA, Warn 8274,Fullcage.
Rep Power: 1 LASTCJ786 is on a distinguished road
I know you can run YJ rear springs on a CJ. I think a 4" lift is a 4" lift
from stock on any Jeep.
Old 03-14-2010, 07:00 PM   #4
TDHofstetter is offline
TDHofstetter
Vehicle(s): '73 CJ5 232/T14/D20/D30/D44, '74 CJ5 Renegade 304/T15/D20/D30/D44, '85 CJ7 258/T5/D300/D30/AMC20
TDHofstetter's Avatar
Rep Power: 1 TDHofstetter is on a distinguished road
It's gonna' be close - I know. I happen to be in exactly that position right now - a couple days ago I dragged home a set of Wrangler springs for one of my CJs. Didn't notice then that they're lift springs, but it's sure obvious now. I WANTED flat springs... oh, well.
They're lifted about 4", and it takes a lot of weight to flatten 'em at all. They'll wind up being a good solid 4" lift, I'm sure, when I've done the conversion (which I may not DO now, unless I can get hold of a set of real STOCK springs).
-- Tim --
Old 03-14-2010, 10:42 PM   #5
73CJ is offline
73CJ
Vehicle(s): 73 CJ5 w/ Detroit lockers Narrowed D44 front and full float D44 rear T14 w/ D20 4 wheel discs, 4.56, 38.5 Boggers
73CJ's Avatar
Images: 15
Rep Power: 2 73CJ is on a distinguished road
2.5" Cj is close to 2.5" YJ but all depends on the spring rate of the pack. Do some Goggling on spring manufactures. They give the spring rate, lengths etc.
My Trail Master 4" had a spring rate of 500#/in. Rode like a tank and cracked the frame by the spring perches. Do not recommend TM. Besides they wouldn't honor their lifetime warranty on shocks.
I've got YJ 2.5" OME now with a rate of 230#/in or so. They are great.
Old 03-18-2010, 10:50 AM   #6
81laredo is offline
81laredo
Vehicle(s): 1981 CJ7 Laredo as built, 1952 Pontiac Sedan Delivery, 1955 Thunderbird, 1958 Airstream, 1996 Tahoe 4X4, 1982 Newell Coach, 1957 Cabin in the Woods what will I work on next?
Rep Power: 0 81laredo is on a distinguished road
would a set of Warngler Springs on the rear of my '81 CJ7 produce a smoother ride?
the wife says we could be rich if I would stop spending money on toys
Old 03-18-2010, 11:29 AM   #7
TDHofstetter
It might, but it might also produce a rougher ride. It depends upon the spring rate.
CJs and Wranglers were all produced with three different spring rates each - soft, standard, and heavy-duty. If your CJ currently has soft springs and you switch to YJ heavy springs, your ride will turn into something similar to that of a farm tractor. If your CJ has standard springs and you switch to YJ standard springs, you may not be able to discern the difference; they compress about as much per inch of travel. If you switch to SOFTER YJ springs, or softer CJ springs, your ride will soften.
-- Tim --
Old 03-18-2010, 12:03 PM   #8
Old Dog is online now
Images: 47
Rep Power: 4 Old Dog is on a distinguished road
81 here's a link that might help you understand what Tim ia talking about
1976 - 1986 Jeep CJ Leaf Springs
Look at the spring rates for both the cj and the yj to see how they differ.
.. http://www.orfw.org/
The Following User Says Thank You to Old Dog For This Useful Post:
Kane (03-19-2010)
Old 03-18-2010, 05:53 PM   #9
81laredo is offline
81laredo
that answers my question.
I have the OEM 6 leafs in the front and 6 leafs in the rear, this looks to be heavy duty springs fore and aft. I did notice the CJ get a bit stiffer with the new polyurethane spring and shackle bushings and shocks (not heavy duty) but some of that was expected since the old parts may have been original. The CJ rides much better with a couple hundred pounds in it (wife and dogs).
I wouldn't mind if the CJ was a bit lower so looks like just shifting to 4 or 5 leaf springs would help, by the way it does ride similar to my Ford 8N Tractor right now.
Could I simply remove one of the spring to get a softer ride or could this create more trouble? If so which one would be the correct one to pull out of the spring pack.
Old 03-18-2010, 09:46 PM   #10
Kane is offline
Kane
Kane's Avatar
Images: 5
81Laredo I have done this before with good results. it is just like when someone puts an add-a-leaf lift and the ride gets stiffer. Generally people will pull out the second or third longest leaf. I saw about a 3/4 inch drop on mine when i had Pro-comp springs. they are stiff springs and this helped allot for ride quality.
conversion, height, wrangler
Normal Height for CJ7 ColoradoCJ7 Suspension and Steering 5 01-26-2010 11:56 AM
crappy headlights?? h4 conversion or hid conversion biohazard cj Chassis and Body 6 12-14-2009 07:54 AM
Lift Height: Want to Fit 33x12.5 tires northfaceboy22 Suspension and Steering 5 08-10-2009 11:04 AM
v-8 conversion davidyoungdoff Drivetrain 9 05-28-2009 05:54 PM
cj to wrangler tub conversion question twiggys cj7 Chassis and Body 3 12-14-2008 06:36 PM
