Default Bump steer
Old 09-24-2011, 10:58 PM   1 links from elsewhere to this Post. Click to view. #1
Germy is offline
Germy
Vehicle(s): 1985 jeep cj7 360 20 rear and 30 front w/warn lockers 5 speed tranny, 1971 dodge dart built 318
Germy's Avatar
Rep Power: 7 Germy is on a distinguished road
Is bump steer when the jeep shoots to a side on a bump? While driving, my steering is feeling good, except for this. When I hit a bump or rougher road, it's a crap shoot if I can keep her in the lines.. I have a dropped pitman, 3.5 lift, 35's. Thanks all, I'm getting closer!!!!!
Default Re: Bump steer
Old 09-24-2011, 11:57 PM   #2
TarheelCJ is offline
TarheelCJ
Vehicle(s): 1979 CJ-7 Renegade, 304, D20, Dana 30 front/20 rear.
Rep Power: 0 TarheelCJ is on a distinguished road
Yes sir it is. I am dealing with the same issue. Bumpsteer is an issue... also oversteer(loose) meaning the back end of the jeep wants to come around in a turn, then you have understeer which is its really tight or hard to turn. I have just had an SOA done and have 35X12.50X15s.... I can't stay in my lane above 45-50 mph and if I hit a bump I feel like i'm going to die ha..... good luck pal!
Old 09-25-2011, 03:42 AM   #3
Germy is offline
Germy
Germy's Avatar
Any solutions? Smaller tires(33's)?
Old 09-25-2011, 06:56 AM   #4
Germy is offline
Germy
Germy's Avatar
From searching posts, I see that I would need to reduce the angle of the drag link. I have a dropped pitman arm, the angle doesn't seem that bad. If I measure from top eye straight down to the level of the second eye, this will tell me if it is 3 inch etc? I am not for sure on the lift height, maybe I need a longer pitman?
Old 09-25-2011, 08:40 AM   #5
get rid of the drop arm and do the flip you will have a better angle and gain back some of your steering radius.
Old 09-25-2011, 08:41 AM   #6
Bump steer happens when you have a lift. The drag link must be close to horizontal or you will have bump steer. If the drag link is angled too much imagine going over a bump and the suspension compresses. The axle (and right steering knuckle) are now closer to the steering gearbox. That forces the wheels to the right. Then when the suspension extends the wheels turn to the left.
The fix is to make sure the drag link is close to horizontal. Some do this with a dropped pitman arm but the best way to a tie rod flip. This puts the drag link on the top of the steering knuckle arm. Like this:
Old 09-25-2011, 08:56 AM   #7
Like dave said you want the drag link to be on the same plan as the tie rod to get rid of bump steer. It should look like this.
Old 09-25-2011, 02:24 PM   #8
Germy is offline
Germy
Germy's Avatar
So I would need to flip the tie rod and the drag link at the knuckle. Is there a kit for this?
Old 09-25-2011, 02:43 PM   #9
sure is http://www.jeep-cj.com/forums/f19/tie-rod-flip-10552/
The Following User Says Thank You to Old Dog For This Useful Post:
Germy (09-25-2011)
Old 09-25-2011, 09:08 PM   #10
Germy is offline
Germy
Germy's Avatar
Old dog, you do know that you are helping with the install, right?!!!!!
bump , steer
LinkBacks (?)
LinkBack to this Thread: https://www.jeep-cj.com/forums/f19/bump-steer-10884/
Posted By For Type Date
Hydro Steering?? This thread Refback 05-21-2013 04:45 AM
2011 Hump & Bump Im Not Spam Jeep News and RSS feeds. 0 03-27-2012 08:20 PM
bump steer cjnewbie Suspension and Steering 10 05-07-2011 10:53 PM
Rockin' At The Hump N Bump Im Not Spam Jeep News and RSS feeds. 0 03-15-2010 04:21 PM
2009 Hump N Bump BajaEdition Outdoor Related 1 11-11-2009 10:37 AM
