Default About to replace steering box. What else should be replaced?
Old 04-01-2012, 09:45 AM   #1
Flex BT is offline
Flex BT
Vehicle(s): 1981 CJ7. I6, Weber 38/38 with TEAMRUSH upgrade. T5, Dana 300TC, Dana 30 / AMC 20, True trac w/ 4.10s. 33" All terrains Blue and rust colored.
Rep Power: 7 Flex BT is on a distinguished road
I've got a new steering gear box on order. Is there any other recommended maintenance I should do or bushings / other parts replaced while I've got the old one out before the new one goes in?
Default Re: About to replace steering box. What else should be replaced?
Old 04-01-2012, 12:36 PM   #2
bondo258 is offline
bondo258
Vehicle(s): 85 CJ7, 258 TBI, MSD6 Ign. TeamRushed TF727, Twinstick D300,outboard shackle rev. f+r Locked Scout D44's , 3" lift, 33's Bondo and Rustoleum.
Rep Power: 7 bondo258 is on a distinguished road
I'd get a new shaft coupler joint. at least re-pack old ones w/grease, and put a new boot on it. Small CV joint repair boots work for this, if you can't find the correct part.
New pitman as well. No cheap ones, either.
Maybe an aftermarket frame support bracket, as well. replace hardware if rounded or rusted.
If power steering, use a turkey baster to remove old fluid from reservoir pump.Replace hoses if soft.
Old 04-01-2012, 01:06 PM   #3
Rep Power: 21 Petescj is on a distinguished road
Make sure to check the frame area for rust and cracks when you take that steering box off. If you have larger tires Id consider a better steering box bracket.
Mountain Off-Road SB7686Z - M.O.R.E. Heavy Duty Steering Box Mount for 76-86 Jeep® CJ-5, CJ-7 & CJ-8 Scrambler - Quadratec
Old 04-01-2012, 02:14 PM   #4
Torxhead is online now
Rep Power: 11 Torxhead is on a distinguished road
Located inside the steering column, there are a couple of items like a bearing and sleeve or something like that to stop steering wheel wobble. So you might want to check that out.
Old 04-01-2012, 02:53 PM   #5
Flex BT is offline
Flex BT
Is the coupler joint in an '81 the 3/4" or 13/16ths? Is one of these what I'm looking for?
Flaming River industries FR1715DD - Flaming River Universal Billet Steering Shaft Joint 3/4"-36 Spline - Quadratec
Flaming River industries FR1758 - Flaming River Universal Billet Steering Shaft Joint 13/16"-36 Spline - Quadratec
Do I need one of these kits as well?
http://www.quadratec.com/products/56113_50.htm
Is a new pitman really necessary or only if the teeth are worn? One of the POs put a drop arm there at some point to compensate for the lift. Still could use the drag arm flip which I'm planning on doing at some point (hopefully when someone will loan me the reamer).
Old 04-01-2012, 04:01 PM   #6
bondo258 is offline
bondo258
Yes, those are what you're looking for. Measure the shafts going in for proper sizing.
The wear part of a pitman arm is the joint where it "bolts" to the steering, not the end it bolts to the box.
If the teeth(called splines) are gone, you have either a poorly hardened steering output shaft, or a poor fit for the pitman arm. spline counts must match. There may be a few different sizes that "look" like the correct part. tou must count and make sure.
Some folks swap in different steering boxes as well. This may be an issue with fluid lines fitting.
Old 04-01-2012, 08:30 PM   #7
Flex BT is offline
Flex BT
Cool. I measured the shaft and it's 3/4" but it seems like the joint is solid (immediately responsive in both directions). A waste of $75 or a good move to replace still?
Old 04-01-2012, 08:39 PM   #8
Images: 219
I don,t consider a pitman arm a wear item. If it fits tight on th old box use it on the new one.
Old 04-01-2012, 08:40 PM   #9
jeepboy45 is offline
jeepboy45
Vehicle(s): 1979 CJ-7, Newly rebuilt AMC 360!, fully rebuilt GM TH400, Quadra-trac TC w/Milemarker 2x4 conversion, AMC mod 20 rear w/1 piece Moser axleshafts, mod 30 front w/tie rod flip and castor correction shims, 4 in lift, Centech complete wiring harness, dual electric fans on 3 core aluminum radiator, tilt steering wheel, 20 gal poly gas tank, new J20 steering box, MSD 6A ignition combined with TeamRush distributor mods
jeepboy45's Avatar
Rep Power: 7 jeepboy45 is on a distinguished road
Hey Flex BT...
Personally, to do a tie rod/ drag link flip, I'd recommend the kits from Goferit... They only cost about $15 shipped. You buy a regular 3/4 drill bit for the task, not a reamer. There is little guess-work about drilling depth that a reamer could entail. Just drill the knuckle, tap in (and weld) the new insert, and re-install the tie rod....
http://www.goferitoffroad.com/products.htm
You might even be able to get rid of that drop pitman. Go find a stock one in its place. Heck, you might even find someone that would trade yours for his.
Old 04-01-2012, 08:40 PM   #10
jeepboy45
jeepboy45's Avatar
RE: tie rod flips....
http://www.jeep-cj.com/forums/f19/tie-rod-flip-10552/
box. , replace , replaced , steering
Help! Just replaced the intake and exhaust manifold Gaskets cfgraneto1118 Drivetrain 9 02-18-2012 09:34 PM
need to replace steering box nanasjeep Suspension and Steering 4 11-08-2011 05:33 PM
Replaced steering shaft ftwflh Suspension and Steering 7 10-09-2010 08:30 AM
Replace Steering Column??? beking Suspension and Steering 8 01-03-2010 07:48 PM
Steering box/rebuild or replace catman Suspension and Steering 13 08-18-2009 09:28 AM
