Electrical Weird turn signal issue
- Atlanta, GA
- 1979 CJ5 Renegade 258, t-18 pretty much stock except for a later model aluminum intake manifold and Gronk 2150.
Trying to get the turn signals working again. I've replaced the headlight switch (original), turn signal switch (broken) and hi/lo switch (broken) and checked the bulbs. My turn signals work in the rear and corners but not the fronts and here is the weird part, when the headlights are on. The indicators on the speedo both light up and don't flash. Weird right? Any ideas? Also if the lights are off and the turn signals working the left front will dimly flash when the right TS is on. The Jeep may be possessed...
