Re: Starting a 65 CJ5 Build but need help with Dauntless 225 swap
ColonelAngus
Hello. I myself just purchased a 1970 CJ5 with the original Dauntless 225. All original for the most part except for Dana 27 front was swapped with a Dana 30, headers with a Weiand intake and a Holley 390 carb, Accell HEI, 2" lift, and missing original seats and hardware. I finally located the seat hardware and will pick it up tomorrow. I replaced the Holley 390 with a brand new Holley 390 mostly because I got it for $50 and couldn't pass it up. But I cant seem to get this thing to run right to save my life. I've done complete tune up, tried 3 different carbs and its making me crazy. I can go out and fire it up and it will run absolutely perfect. Drive it about 3 miles and it starts running like ! I recently sourced a stock intake and Rochester 2 Jet carb and will be putting this on tomorrow and see if this is the issue. If not I don't know what else to do. Motor has good compression on all 6, no vacuum leaks, new filters and all tune up parts. Plugs gapped correct for HEI. I,m starting to think its some sort of vapor lock or fuel lines and filter to close to heat. I've wrenched on hundreds of motors in my 51 years but never messed with the little oddfire before so if I'm missing something please let me know! And since my setup sounds like what you are shooting for let me know if I can be of any help. Thanks
