I need help with a 1969 Dauntless 225 V6 distributor
cj51234
I am working on a 1969 CJ5. It has a Dauntless 225 in it. I believe that this is what is called an odd fire engine.
It is consistently backfiring out the exhaust at high rpms. The vacuum advance is broken on the Prestolite IAT-4502 distributor.
I would like to replace the distributor with a Delco, but I can not find a replacement. Napa says that their is not one. One distributor said the same (rebuild the Prestolite only).
Does anyone have a Delco part number that will work? Or should I grab a 1976 Buick skylark distributor 481693?
