Trans Help with correct transmission mount
- VA
- '76 CJ5, 351w, Ford T18/D20, D44 (open), D30 (open), 2.5" BDS spring lift, 31x10.5x15 tires
Looking for a little help here. Finishing up my 351w and Ford T18/Dana 20 install...
Got the transmission installed on the engine, ordered what I thought would be the correct transmission mount. The holes match up on the adapter plate and skid plate correctly. I knew I was going to drill some new holes in the skid plate to mount to the frame because of the engine swap. Not my concern...
My issue is how tall the transmission mount is. It's about 2" high and I can't jack up the transmission high enough to get the skid plate on the frame. There's a good 1" gap between the skid plate and the frame.
I previously had a 304 and T18/Dana 20. My rear axle was clocked up to point the rear pinion at the output yoke on the Dana 20 and I had a double cards drive shaft from Tom Woods back there.
As it sits now, the output yoke of the Dana 20 is about an inch too high to make the geometry work.
Do I have the wrong transmission mount? Is there a shorter one out there? Has anyone made their own mount?
Any input is greatly appreciated. Thank you!
