Driveshaft vibration with 2" lift
ericweissleder
Driveline vibration with 2" lift
Hi,
I have a 1984 CJ7 with a 2" lift and a new driveshaft - all done by a 4WD shop. After the lift/shaft were installed, I discovered a slight drivetrain vibration. I mentioned this to the shop and got the answer that "vibrations happen" and it'll be very hard to nail down. OK, well last time I go there. The vibration comes on around 35-40 mph, only when under power, and goes away above that. I know it could be anything, but could my pinion angle be slightly off? There are no shims under the rear spring plates... are they needed with a 2" lift? What should the angle be? Is there an acceptable range? To be clear, this isn't akin to a 'death wobble' or anything remotely close—it's more of an annoyance mainly because before those parts were installed, the Jeep didn't vibrate. Any advice is appreciated. Thanks!
Hi,
