AMC 20 rebuild and 1 piece axle conversion
KButler
- Muskegon, MI
- '80 CJ7, SBC 305, SR4, D300, AMC 20, D30, .273 gears.
Hi there, I have a 1980 CJ7. It has ACM20 rear end with .273 gears, both by stamp on the axle and by counting, so I assume they are original. I've had the jeep for a year. This is a driver more than a trail jeep, and will eventually become a daily driver with light trail use. Nothing major. It has 305 sbc, Dana 300, and SR4 tranny.
Everything is leaking out of the rear axle. Pinion seal, rear diff cover, and both axle seals. I am converting the rear axles to 1 piece. I have removed the rear diff cover, and both axles. Drive side axle has pock marks where the bearing would be, passenger side does not. Both axle tubes have a fair amount of road crud inside of them. 1) Is there a good way to clean the tubes without taking out the diff? 2) Are there seals on the inner tubes I should be replacing while I'm this far? 3) I'm concerned the pocking on the driver side will keep the axle end from sealing, is this correct? Lastly, am I creating more problems by not just removing the entire axle at this point and working on it outside the jeep? I've never done work like this before, but I'm not afraid of it either. I do have a shop press and most if not all of the tools I need.
I've uploaded the photos and they are not oversized, but for some reason, when I click on 'insert image' just a box with a question mark comes up... no pic.
Thanks everyone.
Thanks everyone.
