79 CJ 7 wide track rear axle swap
My rear AMC20 shaft is split in 2. I want to replace the entire axle with one from a totally different vehicle. The AMC20 has given me too much grief. Running 31" tires, 3.54 gear. Will use mostly on highway, maybe sand dunes eventually. Yes, it is a wide track.
1. Should I keep the front Dana 30 (which is not cuasing me any issues), or replace as a set?
2. What is a good, almost direct replacement of an axle without going thru alot of extra work?
3. If looking thru a junkyard, what should I look or ask for?
I just want to get this back on the road simple and at reasonable cost.
